Join the Club
John, B.O. and I all have C30s that behave in exactly the same way, so there is evidence that this is typical. John, I get the same squatting and 5.5kts at ~2700 RPM when throttle is WFO, and the same 5kts when I throttle back a bit.When under sail, if the wind is stiff and I'm on a beam/close reach, I can just get over 6kts (GPS) if I can balance & trim the sails correctly, with surges to ~6.5kts. That hull speed value is an abtract theoretical number. I've had more fun sailing since I disregarded it.The C30 is a fat little boat with a beam of 10' 10" on a hull with a LOD of 29' 10". The beam/length ratio is high. This factor comes in to play to prevent it from ever approaching that theoretical hull speed, as well. So don't sweat it.B.O., the filter cannot be restricting fuel flow to limit your RPM. Notice the lift pump gurantees the injector pump on the engine always has all the fuel it can use and then some: the excess is returned to the tank via a recirculation line (that's the other line connected to your fuel tank). The secondary filter, new, allows this high flow rate, which is several times what the injectors can consume; routine maintenance would prevent it from ever getting so clogged that the injector pump would starve. Banish the thought from your mind.JeffP.S.— B.O., there is a small screen at the end of the pick-up tube in the fuel tank, and when it clogs after 20 years, you'll get inexplicable stalling. I've had my '87 since April, also, and had this problem from the moment I took possession. Stalling drove me nuts until I tracked it down. It's simple to remove the fuel line from the tank, unscrew the brass fitting, pull out the tube, and inspect/tear out the screen. But again, I don't think you're suffering restricted fuel flow: we three are all getting the same performance from sisterships with the same engine (allowing for John's after-market prop), so I think you're right where you're supposed to be.P.P.S.— John: yeah, she kickes up a heckuva prop walk in reverse, don't she? :^)
