Love my Martec Folding Prop
Russell
WOW is all I can say. Going from the OEM 2 blade fixed to a Martec folding prop was a rush. We finally got out with out new prop and you could tell the difference immediately. Where we would have been sailing 5 knots we were close to 6. And the acceleration off a tack, what a difference!. We could even point a little higher. If you want to sail leave your 2 or god forbid 3 blade fixed props behind. Folding is the way to go! Only issue was the need to increase rpm's in reverse, not a big difference. Russell
David Moon
Speed under power
Russell, do you know how much speed you lost at cruising RPMs? David
Russell Egge
None in forward
Didn't seem to loose any forward, went up an inch in diameter and it seemed strong in forward. Lost some in reverse. Russell
S. Sauer
Martec Performance
I agree with the assessment that both sailing speed and pointing were improved with no loss in motoring or manouvering under power. I installed a Martec when my 28.5 was delivered in 1986. The only negative we've experienced is a difficulty to 'open' the prop with significant forward momentum. Opening the prop if your speed is 3-4 knots takes a good burst of throttle; which, if only one blade opens, can cause some shaking until the prop is fully open. It may be prudent to 'heave to' or do a 360 for an 'emergency' stop under sail. Our normal proceedure in dropping sails even when single handing, is to start the engine, put it in forward at idle, come head to wind, and drop the genoa. At that point we've lost enough forward momentum that the prop is already open as I increase RPM's and go forward to drop and flake the main without blowing off course with the wheel 'locked'. For larger or heavier boats, or full keeled boats with the prop in an aperature, I'd assume a geared feathering prop would give the sailing performance of the folding prop with better reverse operation (but possibly higher cost). Another plus for a folding prop in Chesapeake Bay, is that you are much less likely to hang up on a crab pot under sail; which makes night sailing with pots around less of a concern.
