Lost power to my AC outlets
37
Catalina 320 MDR
I have a 1990 Catalina 28 that has lost power to my 120 AC outlets, none of them work. My battery charger is working and the panel light turns on so I think I’m getting power to the panel. I’ve pushed the reset button on the panel (circuit breaker?) but nothing happens. Do you think I need a new circuit breaker? Or does anyone else have any other ideas out there? Thanks John
Jul 12, 2004
285
Catalina 320 chestertown
Ckt Switch
AC requires a master switch. Mine has one and I unknowingly and accidentally turned it off one day. When I returned to the boat my AC outlets would not work. Ahhh, I found that switch and turned it back on. Good luck. Paul
Jun 4, 2004
19
Catalina - Myrtle Beach
Also Try
We got our boat the guy at the dealer that took us through it told us that the problem you describe could happen if the GFI in the circuit is tripped. Then it happened 1 day and I'd forgotten what he'd told us but my wife remembered and it was the solution. So if you have a GFI in the circuit also check that. Bill S/V Calico Dragon
