Jerry Villines
It only happens to someone else except this time. My main halyard let go of the main while hoisting said main and is residing in my mast. My initial trip up the mast was not fruitful.Using the topping lift to raise the halyard to mast top was successful except to separate the two and get them on thier respective sheaves. Dropping a line down the mast from the appropriate sheave seams to be the most promising method but was also not successful.Any ideas other than blasting a hole from under the keel upward??? I have a rigger who says he can do it in 2-4 hours at $40 per and a friend who will spend countless hours atop the rig bouncing a line inside the mast.
