Lost Halyard
Tom
While replacing a halyard I screwed up and lost it down the mast. Any tricks on rethreading a new one? I have a climbing harness so can go up the mast. Thanks.
Roger Noble
I haven't used this, but it might work...
Here's one answer, taken from the Catalina mailing list at Sailnet. Al credit (or blame)should go to the author, one Forrest Lott. "A nice carpentry magazine called Fine Homebuilding had this tip for retrieving a wire from a stud space. It sounds like it would work in your case, but you decide. They attached a string of appropriate length into the chuck of an electric drill and tied the other end to a nut. The nut on a string is lowered (in this case perhaps by another nut on a string) to a point where the wire should be. The rotation of the chuck spins the string/nut and it wraps itself around the lost wire. IF it works youve got no holes drilled and not extra cost. As always, Mr. phelps, if this or any other of the IMF ideas fail to work we will disavow any knowledge, etc., etc. Forrest Lott
richard
drop a weighted line down the mast
Then have someone fish around with a bent wire to snag it down at the opening. They can then tape or sew the new halyard on. It is not that hard actually.
Tom
Thanks
Thanks, with the help of a friend we installed a new halyard over the weekend. Tricky bit is getting the new halyard through those damn rollers in the bottom of the mast! We found a bent coathanger very useful for pulling the new halyard out. Thanks for your help.
