Lost asto clearing cloged drain line
Robert
I have a question for an experienced Catalina 350 owner. I recently checked my Rule 800 bilge pump with Blue-a-matic switch contained within the shower drain. I found mildew buildup, so I decided to clean and maintain the same. Upon completion, the drain hose that pumps into a U-line became clogged. I attempted to pressurize the line, and the line kept backing up, overflowing my drain tank. passing into my bilge holding tank. The outhaul valve began leaking water. I am lost asto how to repair the drain line? Would appreciate any help, before calling for professional help. Thank you
Dec 2, 2003
392
Catalina 350 Seattle
Confused
Robert - I'm a little confused by the terms "drain tank" and "bilge holding tank" On my 350, there is a sump "well" in the shower, and the pump/switch assy sits in that sump. The pump sends waste shower water through a "vacum breaker" - upside down "U" - underneath the sink in the head, and then down to a throughhull beneath the sink. The valve on that throughhull needs to be open in order for the shower sump pump to send the water overboard. I don't know if any of that helps or not. Good Luck! Tim Brogan April IV C350 #68 Seattle
