I have a 1978 Hunter 27 powered by a Yanmar diesel. The boat appears to be losing power through the propellor. My speed has dropped below 5 knots. The engine runs fine and I replaced the head and checked the compression rings. Also, I have completed the following: cleaned the prop, checked the compresson, set the valves, pop tested the injector, added new fuel and additive. The cutlass bearing has some play in it and I plan to have it changed when the boat is hauled. Have I missed something in the engine? Does the transmission have clutches that need adjustment? If so how is this done? How long between transmission oil changes? Has anyone experienced this problem? Thanks for the help.
