Bursts in reverse
We use three methods with our prop walk:Use bursts of the prop at good speed, and then reduce throttle and take it out of gear. The result gives motion to the boat, and leaves the rudder to wqork effectively without the effect of prop walk. We have made surprisingly tight turns to starboard in this way. Sometimes alternating the method in forward, and reverse.Set up in tight maneuvering situations so that prop walk is not a problem. (Careful planning ahead, etc.) Use different combinations of lines, pushing off, and other means to get us pointed where we want to go with enough room to deal with the prop walk when the prop is engaged.Use it to your advantage. You'd be surprised how turning to port (in reverse or forward!) can somehow turm out to be the solution to many maneuvering problems.Prop walk seemed a big problem in my first weeks with the Lady Lillie, but seldom now, even when entering a new slip. Just look for us out there, smartly circling to port while we figure out what to do.
