Contacted North Sails
FYI: Because we are all losing battens, it would appear that North Sails has a problem that is costing us all money. I sent the following to North Sails (I will post the results when I hear back from them):"I wonder if you could help me? I have a new Hunter 216 and I have lost the lower batten on the main twice now. Using the www.hunterowners.com website, I have found that other Hunter owners are also losing their battens. Replacing the battens is, of course, expensive. So far this has cost me $44. One of the other Hunter 216 owners theorizes that the batten firsts slips out of the elastic band within the batten sleeve which then allows the batten to flog about until it slips out of the batten pocket and shortly thereafter, the batten becomes one with the ocean bottom. Because I am not the only one experiencing this problem, I would guess there is a design error causing the lost battens.Following is the URL where this problem is discussed : http://www.sailboatowners.com/forums/pviewall.tpl?fno=5&SKU=2004335184212.95&uid=73202826533Do you have any suggestions for a final solution to this problem?"
