Mark Johnson
We use the port side gate to gain access to our boat 95% of the time. Both stantions became loose. I removed the access plate inside the boat and discovered that the bolts go all the way through all right, but there were NO washers and NO nuts on the inside. They were being held there with caulk only. I will have to remove all the inspection plates and check each of the stantions.
