L
Leif Arneson
The (machine) screws attaching the after pulpit stanchions to the deck on my Hunter water ballast are loose and attempts to tighten them have been unsuccessful. It seems that whatever (backing plates?) they were screwed into have been striped. Does anyone know for a fact that there are backing plates molded into the fiberglass (as are other factory installed fixtures on the boat as for example jam cleats and gudgeons) for attachment of the after pulpit stanchions. If so, is the simplest solution to drill and tap the stripped backing plates to accommodate slightly larger diameter screws?
