L
Larry B. Maier
Dear 322 Owners,I am in the process of buying a used 1988 O'day 322. I just got the survey and it was discovered that the wing keel is slightly loose, having a play of about a 1/4 inch. No water was discovered in the bilge. My agent advises that touquing the bolts should be sufficient but the surveyor says drop the keel and re-seat. Has anyone had any experience with loose keels on 322's and if so, do you have any thoughts, advice or experiences? Your help would be greatly appreciated ASAP because I will have to make a decision by 11/15/2000Thanks,Larry B. Maier
