Loose footed mainsail versus slides
Tom
I'd like to know the advantages and disadvantages of a loose footed mainsail versus one with slides. My current mainsail (Hunter 34 used for cruising) has the slides but I'm looking for replacements and it seems like the majority of lofts are recommending loose footed mainsails. Thank you, Tom
W
Warren M.
Loose footed mains
When I bought my new main last year from North Sails in Annapolis, they convinced me to have it loose-footed. They stated that, among other things, the performance of both types would be about the same. In the end, however, they stated the primary reason in favor of the loose footed main was the relative ease of bending the sail on at the beginning of the season. Yet, I've never had any trouble bending on mains with slides or bolt ropes on the foot. Seems like a toss-up to me. While I ordered the sail with a loose foot, it came with a bolt roped foot. North would have altered the sail for me if I so chose, but I didn't want to lose sailing time. I'm happy with the bolt roped foot of this sail....
Bill Colombo
Loose Footed Mains
Tom, I tend to recommend loose footed mainsails in most cases. There are a couple of reasons for this. Since the loose foot is a simpler setup it is easier to trim. By tensioning the outhaul the foot of the sail is able to be pulled absolutely flat. On mains with an attached foot, there is usually some 3D curvature designed into the foot of the sail so that it can have a reasonable shape just above the boom but still return to the straight line of the boom groove or track. Pulling the foot tight will minimize, but not totally eliminate this 3D curvature. This is the reason that in the old days racing mains used a flattening reef, which tensioned the sail on a line just above the foot curvature(these days amost 100% of racing mains are looe footed). Conversely, when you want to make the main fuller and more powerful there is no limitation as to how full the loose footed main can get, since there is no cloth holding it to the boom centerline. As you mentioned a loose foot mainsail is easier to bend on to the boom. It also affords much more flexibility when rigging such thing as, reef lines, jibe preventers, vangs and other things that require tying a line around the middle section of the boom. I would suggest you try one of these mainsails. Most people never go back. Thanks, Bill C. Doyle Sails
