K
Kenneth Pfaff
I was doing some routine cleaning and checking engine fluid levels on my new 290 when I saw a bolt nut and washer laying under the engine. I determined it was one of the 4 bolts which connect the drive shaft to the transmission. I checked the remaining 3 bolts and all were loose.I re-assembled it and tightened all the bolts. My question is "is this some that I will have to check on a routine basic or is the problem with the commission of the boat?. I've only had it for 4 weeks"
