Loos specs for Beneteau First 310
Jul 17, 2009
12
Beneteau First 310 2 50 Point Marina, Lake Ontario
can anyone share the tension settings when using a Loos rigging gage? Also, to which of the 4 holes do other owners bolt their furling?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
You might be interested in thread discussing rigging tension on a Catalina 310 and article from UK on tuning and Loos entitled "How to use PT Series Tension Gauges" in case you do not have it. Maybe too obvious but you might consult with your rigger.
OWI
Apr 17, 2020
16
Beneteau First 310 Milwaukee
It is 20 for the outer stays and 15 for the inner. Make sure that your stays straight as you tension both sides a bit at the time
OWI
Apr 17, 2020
16
In the manual it says how much rake the mast should have by taking a straight line ( hallyard) from the top to the deck. I forgot the distance but it equates to 20 on the gauge for the outers. Then take up the slack with the inners. Equates to 15 on the Loos gauge.
