Looking to downsize from CAL 39 MK2 to Trailerable sailboat - Coast of Maine sailing
Jun 29, 2011
11
CAL 39 MK2 Brunswick
The costs in Southern Maine for Storage of a 39 ft sailboat have become prohibitive at this point (plus I am getting older and I do all my own work). My wife and I typically spend 4-5 weeks cruising the Maine coast in the summer (yes I realize how fortunate and therefore grateful I am). I am looking for a sailboat that I can trailer (store at home) but that we can at least spend 1-2 weeks at a time living on. I have been researching shoal draft sailboats in the 25-26 ft. range that are on trailers, and have come up with: Watkins 25, Seaward 25, Com-Pac 25 (really expensive), O'day 26, Bayfield 25, Cape Dory 25, Hunter 25, and Tanzer 25. I owned a Catalina 25 long ago and felt it was poorly designed (prop to rudder location) so I left it out of the list. I would like an inboard diesel if possible, but I realize that they will all feel really small after the cruising boats I have owned (Pearson 365, Whitby 42, Cal 39). I would love some input from the folks with experience in cruising this class of sailboat. I am not looking to race, my wife loves living on the boat but she is not happy heeling more than 20 degrees. A usable head and galley are necessities as well as trailerability. Thank you for your thoughtful feedback to come.
Many years ago I owned a Tanzer 22 and cruised it on Lake Ontario. The boat was well built and sailed well, it has been my favorite for sailing. Space in the boat was tight, it will be a bit better in the 25. Tanzer has a reputation for building heavy boats, my 22 weighed in at about 3,000 lbs. The mast section was beefy for a 22 foot boat, it was the same mast section used on some of their larger boats. On the 25 you'll probably want to use a gin pole to step the mast.
As for the other boats on your list, I would look closely at the Com-pac, Seaward, and Cape Dory.
Good luck!
Likes: JBP-PA
Andy... Sensible request.
It is difficult to suggest if there is a limit to the ability to trailer the boat. If you're hauling the boat with a Subaru Forester, you need to think light and nimble with a rig of less than 2000 lbs, boat, and trailer.
If you have a Freightliner Cascadia 125, your options will be expanded.
If not sure, perhaps an indication of the towing weight would be a good place to start narrowing down the possibilities.
dmax
Jul 29, 2018
1,246
Telstar 28 Buzzards Bay
The Nimble 25 is an interesting boat, probably not real fast.
Jun 29, 2011
11
My towing vehicle is a Ford F150 capable of 5000 lbs. Also my marina (mooring) is about 10 miles from the house all local roads (<35 mph posting). The boats I listed seemed to all have displacements less than 5000 lbs
801
MacGregor 26s Scott's Landing, Grapevine TX
I was going to throw the MacGregor 26 into the ring but the 20-degree healing parameter popped up. It seems to me that that would eliminate any water-ballasted boats in winds approaching 15 mph. A cast-iron or bronze centerboard would be required, which or course affects the trailered weight. The thing that sets the 26S, X, and M's apart from so many other boats is the queen-sized berth under the cockpit. I have the S, but my wife would prefer an X or M because of the 6' headroom in the cabin. Of course, the X and M models being motor sailors is a big draw for many, especially those who would like the option of beating a hasty retreat when bad weather blows in.
I know that many don't think of MacGregors as "real" boats, but IMO, except for the 20-degree healing thing, they offer advantages other trailer sailors don't. At any rate, I think that you will be challenged to find a truly trailerable boat in the 26-foot size range that will satisfy the Admiral in regards to healing.
Likes: LloydB
BarryL
May 21, 2004
1,088
Hello,
Are you looking for a boat that you launch in the spring and recover in the fall, meaning the only time the boat will be on the trailer is during the 'off' season? Or do you plan on launching and recovering multiple times a year?
If you plan on doing multiple launch / recover then a smaller boat in the 22' range would be a lot easier. However, as you note, living aboard a 22' boat for over a week is not something most people would enjoy.
Note that a trailer large enough to handle a 25' boat will probably weigh over 1000 lbs, putting at or over the towing capacity of your truck. Of course for a short drive on flat terrain you would probably be OK.
If you only will launch / recover once a year then I would suggest a boat in the 27-30' range. I would not launch or recover that myself, I would pay a yard to do it, and I would hire a transporter to move it to my properly. I used to have a Newport 28 w 5' draft that had enough amenities for a week or two (for 2 people). It had pressure hot and cold water, decent sized ice box, stove, head with holding tank and a comfortable salon and V berth. I think just about any 27-30' boat with a shoal draft would work for you.
Good luck,
Barry
JBP-PA
Apr 29, 2022
692
Jeanneau Tonic 23 Erie, PA
Allow me to add my boat (by definition the current best boat in the world) to your list. Jeanneau Tonic 23 (or the 27, or the beneteau First 23). It is in the same class as your list. It has a full, enclosed head, galley, two double berths. Standing headroom is 5', 10" max at the companionway, 5', 7" in the salon. If you get one before the early/mid 90's they are stoutly built and strong. There are both centerboard and fin keel versions, inboard diesel or outboard versions. Displacement is about 3,000 lbs, full trailer weight about 4,000 pounds. I tow it with a Toyota Highlander rated at 5,000 pounds. I regularly go on month long trips with several days at a stretch at sea.
Jun 29, 2011
11
Thank you for your suggestions. I am researching all recommendations so that I can get a better understanding of what
is out there for trailerable cruisers - I plan on trailering from the mooring to my home and storing the boat on trailer. About a 10 mile run, mostly back roads at less than 35 mph
pgandw
Oct 14, 2023
182
Stuart (ODay) Mariner 19 Yeopim Creek
Just my thoughts - worth every penny you paid. If the ODay 26 is anything like the ODay 25 predecessor, it had too fat a rear end to ever put the rail under. It would start to heel, and the rub rail would be starting to approach the water. The big butt would immerse, causing the outboard transom-mount rudder to lose its grip. She would round up and straighten up. As it was the rudder was an inch or so deeper than the keel stub with the centerboard retracted, so a deeper rudder was impractical. Learned to reef to keep her reasonably flat. DW liked the fact I couldn't capsize the thing no matter how hard I tried.
She and I sailed the ODay 25 from Miami through the northern Bahamas for 4 weeks, from Key West to Dry Tortugas, and from Spanish, Ontario through the North Channel twice. Second time was with 3 kids. Reasonably trailerable with a Suburban for tow vehicle. 5ft cabin headroom, 28" draft, way too much boat for me now in my old age, although I miss the stability and comfort. I was so much younger then. Got rid of the stock stove, used a portable camp stove in the cockpit. Chrysler 9.9hp outboard for power. Had a used Avon dinghy with 1hp Sears outboard.
Now mostly single hand a 19ft Mariner. Tows easily behind a mid-size SUV. Room enough for max 2 to camp cruise, bare min headroom, electric outboard.
Fred W
Stuart (ODay) Mariner 19 #4133 Sweet P
Likes: LloydB
Jun 29, 2011
11
Thank you for your input on the O'Day 25-26. My question is regarding the outboards effectiveness in non-flat seas. I am concerned about getting into rough seas and having the outboard cavitating and loosing the bite and therefore loosing control / headway in not only following seas but also rough seas. What was your experience?
pgandw
Oct 14, 2023
182
On the ODay 25, I rarely used the outboard - Chrysler Sailor 250 9.9hp - in anything but fairly calm conditions and docking. Had a long shaft and one of those raise/lower brackets. The occasions (3) I do remember motoring in winds/seas, I never remember the outboard lifting and cavitating. I do remember it dunking once when I was crossing the bar outbound against breaking seas at Little Harbor in the Abacos. The motor kept on running. At the next port, I fresh water rinsed the powerhead and wiring, sprayed it with WD40. Later cleared off some corrosion at the wire terminals, but no other problems. When I broke the lower rudder gudgeon about 15 miles from Bimini, I used the motor to power and steer the boat into Bimini for repairs. It was a rather painful experience leaning over the transom to steer for 4 hrs, but it worked.
Very similar situation on the Mariner (19ft) - the bracket provides enough up/down to ensure the motor goes deep enough, yet comes out of the water when tilted at the top position. This is true with both the long shaft Honda 5hp I had, and the current long shaft EPropulsion electric I use. In fact, on the Mariner the lowest bracket position is too low, and I seldom use the motor all the way down. The only time I would consider all the way down is when motor sailing on the tack that lifts the bracket from the heeling of the boat (starboard tack on the Mariner with mount on starboard side).
I usually steer with the tiller, and not with the outboard, leaving the outboard in a locked straight ahead configuration. On the Mariner, I found I need to have some centerboard down (4" is usually enough) to provide steerage under power. Otherwise, Mariner "skids out" when trying to turn sharply.
With the electric, I tend to use the motor a lot more than when I had gas outboards. But still no problems with cavitation or following seas as long as I lower the bracket far enough. People that use short shaft motors or fixed mounts or steer with the motor tend to have more issues.
Fred W
higgs
Aug 24, 2005
3,713
Nassau 34 Olcott, NY
Consider the Marshall 22 catboat. I downsized from a 34 to a Marshall 18. It was a bit of an adjustment, but I now find i enjoy the boat. They are simple to sail once you learn the system.
