Hello,
I am looking for a reasonably priced chart plotter and depth finder that has buttons. In my research I found the following:
- ECHOMAP™ UHD 73sv U.S. Lake
- ECHOMAP™ UHD 74sv Bluechart
First, what is the difference between these two? Only the maps? I plan on buying Navionics maps anyway since I am familiar with them from phone and current fish finder, am I better off saving money by buying the lake, and upgrading to Navionics, I am on the coast of New Jersey and assume I need ocean/coastal maps.
Second, I would like to buy a thru-hull transducer. I have one currently, but the cable is cut and it's in-op. I located the following that I think would work with the above chart plotter:
- Airmar Transducer B150M 20 degree tilt. (Garmin PN 010-11927-22).
I have a new Raymarine Autopilot system (EV100) I plan on upgrading too as well, which uses the SeatalkNG network, in case that has an impact on selection; Raymarine chart plotters with buttons seem very expensive for a 30' sailboat.
Working your way through all the weeds of integrating components is a PIA, geesh. Any help is appreciated. If you think there are better options too, I am certainly open to them.
Thank you,
Snoopy
Thank you,
Snoopy
