Looking for km3a or km3a shaft kanzaki
ksmax
Apr 11, 2020
3
Hunter 34 Quebec
Hi!
I am having trouble with my output shaft starting to wobble between shaft and coupling on my kanzaki km3a
Willing to buy a new km3a as an exact replacement or a shaft that is still good!
Km3a goes on my 3gmf
If you have part or kanzaki for sale, inbox me!
Thanks a lot for your help, I really need it right now
Marc
Nov 6, 2006
10,102
Welcome to the Forum, Marc..
Another option might be to have a machine shop make a new coupling flange, custom fit to your existing shaft, but with the same seal fit. You'd probably have to remove the gearbox and take it to a machine shop to get that done.
ksmax
Apr 11, 2020
3
Hunter 34 Quebec
Hello Kloudie
Thanks for the welcoming words!
1st: You don't know, but thank you so much for all your contribution in this forum, you've helped me soooo much for the last 2 years with my hunter 34. (Engine/mast post/windlass and much more!)
2nd: the transmission is already appart. I thought the part time clunk trouble was due to the clutch cone so I bought a new one. When the mechanics opened it up, we saw that most of the trouble was the play between the shaft and the coupling.
He sais its worn in both, I can't just buy a new coupling and hope it's perfect (250us) Can a machinist make a thigth fit coupling to an unaved shaft after knowing itals worn on both? I can't see the worn part from my eyes on the shaft tho...
The coupling is still avalaible.
The shaft isn't since 2009 and haven't found any online.
I've sent a few quote for the shaft to machinist. The answer I've got so far are negative, mostly because of the middle part. Maybe I'd get better answer with the coupling?
Thanks for your suggestion, all help is really appreciated. I am seing my 2nd winter in the bahamas slowly drifting away haha.
Marc
Likes: kloudie1
Dec 14, 2003
1,433
Hello Marc and welcome to the site. If you need info about someone who can rebuild your transmission I have a very good contact in Sorel/Tracy. Your post show Quebec and it does look like it might be easier for you in French, so II'll try sending you a private message with his coordinates. If you don't get it, send me one with yours and I'll forward the info.
Likes: kloudie1
