I need to change the fuel filter on my 2GMH Yanmar engine but can't find the Racor filter number(or Dahl--both are recommended). Does someone have that number handy, please, or know where to look it up? This is a Hunter 31 '84. Thanks again. Bill
if you are talking about the small engine mounted fuel filter you should use the yanmar. If you are talking about a filter between the engine and the tank you will need to get the manufacture and the model and buy the appropiate filter or equivelent. The yanmar # is 104500- 55710. You will also need to buy the "O" ring,yanmar part # 24341-000440. Check out the site below for a quick reference parts sheet under diesel engines then go to yanmar.
Bill:These boats did not come with the Racor installed. I think that they had a canister type filter on the original boats.You will probably need to check out the filter for yourself to be sure. I would recommend that you use a 10 or 30 micron filter vs a 2 micron filter. I believe the engine filter is 2 microns.
