hi,
i'm considering buying this hunter 280, 1996,
1. wing keel has a dent at the bottom and crack at the top as shown in picture, i'm not sure is the crack is superficial or deep. any idea if the bolts or the fiber might have damage?
2. also the heat insulation under the engine cover is burnt, does this mean engine is burnt or just overheated. how much would it cost to buy and install a new/used yanmar 18hp?
3. bow has a small dent you can see the fibers, can this be fixed?
thanks a lot.
thanks a lot.
