Looking for a Vega in EU
Oct 30, 2019
14
Hi!
I'm looking for a "project" Albin Vega boat in EU.
I have 2 very simple requirements:
#1. Good-to-perfect state of the hull plastic (no osmosis, delamination,
or lightening strike)
#2. Engine which will run at least 250-300 hours.
A friend of mine bought a Vega which stand in a shed for 30 years in a
row, she wasn't very nice looking, but plastic (and original gasoline
engine) was in a perfect state. I want similar boat too. [:)]
I don't need a completely refitted boat. I'm going to do it myself. For
a few years (since Sept 2004) I was thinking on building my boat, I even
bought 2 projects (B Roberts' 31 feeter and a "Dudly Dix like" 26
feeter). However, I didn't start building scaring that I won't be able
to make it as reliable/nice looking as it should be (all projects I took
look at (more than just 2 I bought) hadn't any reliable drawings for
interior, just a few photos in a "how you could do it" style, no
electrical schemas, no types and masurements for deck hardware and so
on). After careful looking through the albinvega.nl
albinvega.nl web site I understood that it is exactly
what I need - a boat which I will refit I like to refit which will
guide me in right directions in doing it and in the same time with
escape of building completely custom boat...
I saw a few boats selling cheap (mostly for free) in US, but it isn't an
option. Vega doesn't fit into marine container (4 inches wider). I'm
sorry.
[Non-text portions of this message have been removed]
Nov 8, 2001
1,818
Hi
I wish you luck in your search. There is no gurantee that an old engine
will last for 250 - 300 hours, especially the gasoline Albin 021/022 !!
Where do you live? Even if a Vega did fit in a container the cost of
transport would surprise you!
Very few, if any, Vegas have Osmosis so I do not see that as a problem.
Good luck in your search and keep us all informed about your search.
Cheers
Steve Birch (Technical)
Oct 30, 2019
14
Hi, Steve!
You know... I typed reply to your message a few hours ago, but it
into nowhere... So, here is another version...
Nov 8, 2001
1,818
Hi
The cheapest country to buy a Vega is in Sweden. I suggest you buy one
with a diesel engine but they are still very old (30 years) and parts
for the engines are very, very expensive.
Hope this helps.
Cheers
Oct 30, 2019
14
Hi, Steve!
Well... I think that here are a few opinions (yours and mine :) ) re
which country Vegas are cheapest in... The cheapest Swedish project
Vega I found on Internet is about $6500, which is at least twice
expensive than project Vegas for sell I found on this group. I don't
think that extra $2-3K will hardly abuse my budget, just "absolute
values" comparison. So, personally I don't think that Sweden is
cheapest place for Vegas even they were sold mainly in Sweden...
However, (as far as I understand) there is a lot of totally unused
Vegas, which makes Sweden primary place for research.
Another good side of Sweden is that it is very close to Poland and
Polish Gdansk port, so I can motor or sail to Gdansk only and to
order local track to carry her directly to my home, which looks
neat. :)
Thanks! :)
Oct 30, 2019
14
By the way re old engine.
I planned to install Beta engine. The only problem I see there is
that 13.5 hp (as far as I understood it is biggest engine suitable
for Vega) seems small to me... Calc is pretty simple 5 hp per 1 ton
of displacement, Vega is 2.3 tons, so it is 11.5hp to fit, however we
need to add at least 30% of power for bad weather conditions, which
gives us 14.95 hp, plus lose of power on pump, alternator and gear
box (we assume that prop works OK and don't count lose of power in
hot weater conditions), which close to 1 hp, so we have (rounding) 16
hp, then we take a look here
Beta Marine - Marine Propulsion Engines & Marine Generating Sets at diagram
for BD722 and see that we get required power at 2500 rpm, which is
too fast rotation for a disel engine. So it comes, that adequate
engine for Vega is BD1005, and with real minimum of BD722.
Can you comment on this...?
Oct 31, 2019
303
Actually the modern diesel is designed to run at higher RPMs than the diesel
of years past. The modern diesel is very light weight compared to those of
old, and thus are designed to run at the higher speeds. The Kubota, that is
used for the Beta is an industrial engine that is often run to power
generators or refrigeration units and they often run for weeks on end at
high RPMs. But I still had problems running at the higher RPM since I am
used to the Diesels of 30 years ago. So I started researching it further.
Rather than using RPM to do any calculations, it is more telling to use
piston speed. That makes sense because that is where the real "wear and
tear" exists - the banging up and down and not the rotation. As a rule of
thumb a piston shouldn't travel more than 2500 feet per minute. For optimal
life of the engine, it is better if it is kept around 1500 for long
stretches of time. Doing the math with the Beta 13.5 engine it clearly shows
that even at 3600 RPM the piston travels 1600 feet/min (if my math is
correct). At 3000 RPM it is about 1350. Both of these are below (or just
above in one case) the 2500 and 1500 rule of thumb.
As I said I have struggled with the notion that diesels need to run at very
low RPMs. When I had my 39 footer, I had a Volvo engine that put out about
38 HP. I was told by all the mechanics and the Volvo dealers to keep the RPM
about 3000 RPM and occasionally I would run it that high. But I usually ran
it around 2000 RPM since at the lower RPM, I used under 1 gallon of fuel an
hour, while at 3000 I would burn 2.3 gallons/hr - and my speed gain was
barely a knot - not economically feasible.
_____
From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] On Behalf
Of Alex_lp
Sent: Monday, December 18, 2006 1:24 PM
To: AlbinVega@yahoogroups.com
Subject: [AlbinVega] Re: Looking for a Vega in EU
ne.co.uk/beta_brochure/beta10-20bhp.pdf at diagram
Nov 8, 2001
1,818
Hi
Having supplied and fitted so many Betas to Vegas (SUpplied 122, fitted
11), I think I can comment on the suitable engine for the Vega.
In my opinion the ideal engine is:
1. BZ482 (13.5HP at 3600rpm). Fits beautifully and works well. 2
Cylinder
2. Beta (16HP at 3600rpm). This is a new engine based on the Kubota
600cc block. W ehave now suppled and fitted a coiupleof these engines.
Do the job well and only very slightly bigger.
3. BD722 (20HP at 3600rpm). I have supplied a few of these engines for
Vegas (3) but I consider them overkill. The Vega is a sailing boat after
all!
I have a friend who has a Sunrider 25 which is a similar weight to the
Vega and he has put a 40HP Perkins in his engine. He now has a
motorboat!!!
Hope this helps. All in my opinion only.
Nov 8, 2001
1,818
Hi
I agree that sometimes in teh US you can find a very cheap "project"
Vega but the logistics and cost of transport makes it uneconomical. You
have to travel to see the condition of the Vega before you buy so your
own air flight cost must be added as well as travel expenses. I am not
trying to put you off buying a cheap Vega but I have experience of
buying a Vega in Sweden denmark as well as the UK and Holland.
Cheers
Oct 30, 2019
14
Hi, Steve!
I didn't mind to cancel my Vega project just because they aren't
available in Sweden for $3500. :)
I contacted a Swedish boat dealer and asked for help. I hope
everything will be OK!
Thanks!
Oct 30, 2019
14
Hi!
Can somebody tell me Vega height (without mast) masured from the keel
foot plate to the most top point on the deck?
I found a carrier who is able to bring yacht from the USA to Black
Sea for $88 per 1 cubic meter. Guessing that full height is 2.5
meters, I get $4.5K for shipping which is not bad.
Any help is highly appriciated.
At the moment there is no luck in finding a project Vega in Sweden
for an adequate price. Average price I found for a project Vega is
around 6000 Euros (7800 USD). Plus about 2000 Euros (2600 USD)
shipping, so I get over $10K with a project boat (plus I need to pay
25% of customs fees, but it is another story).
Thanks,
Alex
Mar 28, 2011
261
Alex,
Be careful what you do purchasing an American/Canadian Vega. The minute you sail from your home country to one of the European Union countries, you will be slammed with a demand for the VAT !!!! Which can vary from 18 percent of the boats assessed value in Greece (the customs people will assess the value, not you) to as high as 25 percent of the assessed value in countries such as Sweden, Finland or Denmark. This is of course on top of the customs that you will pay at the port of entry where she will be delivered. The following happened to me. My Vega was a "European" Vega, meaning she was first sold in Germany and the VAT was paid at that time. I later bought the boat and had her shipped to the states. Years later I had her shipped to the Netherlands, where customs duties were assessed, plus 19 percent of the boats value as VAT, because I did not have proof that the VAT had been paid. The Dutch customs would not listen to reason or logic that if the boat was
first sold in Germany in 1973 that the VAT must have been paid (it is German law, you cannot buy a new boat without paying the VAT). And I ended up paying customs and the VAT. Think about it. The price of the boat, customs taxes, VAT, plus shipping costs, and if in the end you do buy here in Europe, make sure you get proof that the VAT has been paid.
Frank Gallardo Jr
V-2184 sv Cin Cin
"May the warm breeze at your back not be your own"
Alex_lp alex_lp@... wrote:
Hi!
Thanks,
Alex
Oct 30, 2019
14
Hi, Frank!
Situation is better and worse in the same time.
Republic of Moldova (where I live) is not an EU member. So I will pay
local VAT anyway. ((Boat_price + shipping_cost + insurance_cost) + 5%
customs_fees) + 20% VAT. That is the formula.
So, I do not care if USA/EU VAT paid or not. I will pay it here
anyway. It would be nice if there would be a way to get VAT return
during export from Sweden to Moldova and as result to reduce total
cost. But it isn't an option, because buyer (me) is not incorporated
(company or whatever) and as result I'm eligible to get VAT return.
Good side, that if I sail to EU I will not pay VAT in EU if I do not
stay there for more than 6 months.
Oct 30, 2019
14
Hi, Steve!
Original question was - what is the Vega height. ;)
Re container
Yes. I know that she doesn't fit (2 inches wider) into a standard
marine container. If she would fit, shipping would cost me $3400 for
container (for example, Chicago-Odessa) and $3800 shipped to my door.
Some people advice me to put lots of used tires inside the container
and to ship her sidelong. I'm not sure that it is OK. I scare that I
will get a set of cracked plastic parts. Also, I don't know who will
do it (filling container by used tires, gently laying boat and so
on), because I think to do everything remotely, without visiting USA
(it is quite difficult to do, than, for example, to visit Sweden).
Those guys (carriers) ship her in hold of a cargo ship. Company is
Atlantic Ro-Ro Carrier, they shipped lots of non standard things,
like Dodge RAM 3500 pick-up which doesn't fit into a marine container
too.
Thanks,
Alex
Oct 30, 2019
14
Read:
As:
and as result I'm NOT eligible to get VAT return.
