Looking for a swim ladder for a H25.5 1985
Urchin
Mar 6, 2017
6
Hunter 25.5 Asheville NC
The bottom half of my swim ladder fell off recently while I was towing my H25.5 back from Florida. The mounting brackets are still there but the 4-rung swing down ladder is somewhere near Ocala. Cant find a replacement on the Hunter site....any suggestions?
Thanks
Nov 26, 2012
1,654
C&C 40-2 Berkeley
Ahhh, the swim ladder conundrum. I had the same boat and I needed a swim ladder. The problem is that there are so many pieces of junk swim ladders put there. I ended up spending a little more and got one from WM that mounted to the stern using a pair of "keyhole plates" that mounted to the top surface of the stern. Each vertical post of the ladder had a screw on the end where post curved over 180 degrees that fit into the slotted hole in the plate and held fast. Worked great. The reason that I tell you all of this is that I found the biggest problem with ladders is getting one that stays in place while you are using it. This one did.
Urchin
Mar 6, 2017
6
Thanks for the feed back. I will check this out - is WM walmart? Did you consider a ladder with a teak platform at the top with 3 rungs beneath?
