Looking for a burner base
bletso
Aug 20, 2013
106
Globe 38 PCB
I am looking for burner base for a pressurised kerosene Shipmate heater. The one I have is cracked. Burners are readily available but the bases?? It cracked when water got into the fuel can. I thought it was fixed but... cabin-heater The burner is a standard Patra 207 used by a couple different manufacturers. My web searches have ended without success.
May 20, 2016
3,015
Hard to see, but could you braze the crack and burry it in sand to anneal??
bletso
Aug 20, 2013
106
Globe 38 PCB
I have thought of that and I may have to but is a very tight crack and getting rod to flow may be problematic.
bletso
Aug 20, 2013
106
Globe 38 PCB
Well as it turned out the base isn't cracked but the threads are stripped. Found out the hard way. I was checking it out, off the boat of course and all of a sudden after making an adjustment, kerosene every where and fire. No problem. SO I am definitely looking for a replacement.
