Looking at purchasing a 22
Morris
I am insterested in buying a used 22, but would like some advice on what to look out for. Are some years better built than others? Is it better to get a fixed keel rather than a swing?
F
Frank Taylor
Buying a C-22
I sail a 1979 C-22. I know people sailing C-22s both older and newer than mine. On the swing-keel boats you should verify that the bronze keel fitting and bolt are in good shape as well as the cable and winch. On an older boat you can probablly expect that the sails and standing and running rigging may be worn out and need to be replaced. I am still using the original sails and standing rigging, although I plan to replace them soon. These are minor issues if the rest of the boat is sound. Interior cushion covers can be worn out but are easy to replace if you can sew. As for which keel is better, that's a matter of where you sail really. If you're going to keep your boat in a slip and water depth is no issue, the keel version may be the better choice. If you're intending to trailer your boat and have to use a launching ramp regularly, or if you need to sail in shallow water, the swing keel may be the better choice. I've had boats with both types of keels and am perfectly happy with my current swing-keel boat. One advantage, usaully, of buying an older used boat is that it generally comes with a lot of extra gear, like anchors, cockpit cushions, radio, etc., saving you the cost of buying them. As long as the hull and deck are sound and there are no major leaks or other apparent damage I would not be afraid of buying an older C-22.
Dan
Examine the boat well.
Don't be afraid to tug on the rigging and pound on the hull. Look for water stains where through-deck fittings come inside. Make the seller spread the sails out. Run the engine. Has the trailer been serviced? Salt water or fresh water? Is the boat haunted? LOL
Rod
My 2 cents
I just bought my '84 C22 this past April and while I am lucky to have found a good boat I wish I had known a few things, including: 1 -- In 1986 Catalina made some upgrades to the boats. The galley placement and some other features got an improvemnt. 2 -- The Catalina Direct owners handbook has some great info. Read it before you buy. My boat came with the manual, since reading it I have learned a lot about the differences in the model years. (www.catalinadirect.com) 3 -- If the boat you look at is pre-86 be sure it has a galley, many of them are missing. Even if you don't use it, you can sell it here. 4 -- I'd check the wiring too. Make sure all of the lights are working. Not a huge deal, but I forgot to check these before I bought my boat. 5 -- Look for weak places in the hull/deck. 6 -- Trailer condition is important. Be sure the breaks on the trailer work or if not how to repair them. 7 -- Investigate the keel bolts, winch and cable. Look at a lot of boats. Rod
John
Do your Homework
I bought a '74 last year. The boat itself is in great shape but had I known alittle more about what to look at prior to buing I might have passed on my boat. I had to replace the keel winch, main sail, sail cover, all running rigging, bottom paint, and get new wheel bearings/seals. I also have gained alot of knowledge about this boat. I'm def. not complaining either, I love to sail her. And when I move to another boat I can probably get back what I paid, maybe alittle more!
