More lightly built?
David:What does this mean to a future purchaser?Actually each future generation of Hunters has been better built. Even within the run of the first generation Hunters (Cherubinis) the boats got better.First of all there were no differences in the laminates on a Cheribini hull verses the boats built today. The same person that determined the fiberglass used to build a hull in the 70's and 80's is still the same person who does so today. The only thing that Mr. Cheribini did was to design the boat. He had nothing at all to do with production, determining the fiberglass thickness and where it required more or less or the quaility in which the boat was built to. Mr. Cheribini designed a wonderful boat but as you have already said, he was just the designer.There appears to be a myth out there that the Cheribini hulls were built thicker or stronger but nothing is farther from the truth. They were doing exactly the same techniques as they did in 1980, laying in the same amount of materials with overlaps in the same locations, etc. The only differences today are that they use different materials such as ISO-NPG Gelcoats and Vinyl Ester blended resins and better stitched fiberglass.Beyond this point, the rigging on later boats were up to date. They where much stronger. The design of the toe rails were improved to minimize leaks. The cabinets had better materials, fit & finish. Many of the improvements that have been made to these boats where made by the owners (holding tanks, engine upgrades, plumbing, lighting etc.).As I have said before, If I could have my interior and rigging in a Cherubini designed hull I'd be a VERY happy owner.Happy none the less.
