Hunter 30 thoughts
I bought a 1982 Hunter 30 in August and have been refurbishing her. A few of the things that I have found on mine (which, prior to my purchase had taken on fresh water to 4 inches in the cabin) This was caused by the cockpit drains. Both hoses had cracked. There are also leaks in the fiberglass around where the hoses connect. It looks to me like it was caused by poor original construction, and has probably leaked for her whole life. These have been repaired. The boat is dry, now. The biggest concern is a rusted mast support in the bilge. I will be starting on that repair in a few weeks. Another problem was broken port latches. I came up with a solution by cutting off the broken base and fabricating a new one out of brass. All of the port and hatch gaskets needed to be replaced. Balmar sells these for the Gray ports. All of the ports will need to be re-caulked. I have been told to trash the Combi electronics system. The Skeg has a separation from the hull of about one quarter of an inch. Not sure if this is normal. Does anyone have insight into this? Is it normal? My surveyor said to tighten the bolts. The mast has galvanic corrosion where fittings are attached. The surveyor thinks it is minor, but we will check when I remove the mast. I will be replacing most of the hoses and tubing. Otherwise, the boat seems solid. The hull has no blisters, even though it sat at the dock for about five years while the previous owner neglected her. The interior is in great shape, excepting a vague water line- no rot. One more thing. Be careful when working inside the storage areas, behind the wood trim. There are screw points that protrude inside. I have a cut on my hand that is still healing. I will be grinding these.Good luck! I am happy with my boat, so far.I have not sailed her, yet. I hope my wife and I enjoy how she sails, after all of the work.
