long term storage on land
Sep 21, 2017
2
Hunter 33 Swan Point
We are thinking of leaving our boat on land (it is currently for sale) after we have done our usual winterizing. We wonder if there are long term considerations re the engine, batts and other working systems. We do not want to damage anything during this time. We are probably going to continue the battery charging that we usually do over the winter but also wonder if we should just plan to buy new batts when the boat is sold. Is there anything else that we should do for the boat's long term care?
Jan 24, 2017
672
Hunter 34 Toms River Nj
1. Hang moisture bags
2. Moth balls in storage compartments to keep wasps and other animals out.
3. Gallon of bleach in each water tank, fill tank, let sit for a week then drain and winterize to prevent mold.
4. Lightly spay engine with wd-40 to prevent rust
5. Change oil, trans fluid, and antifreeze to eliminate any acids.
6. If possible get some oil on top of pistons.
7. Plug air intake and exhaust.
8. If possible solar fan and vent cabin
9. Put a couple of 5 lb bags of charcoal around the cabin to absorb any odors "note" don't use charcoal with lighter fluid in it, just use regular charcoal. This works better then kitty litter.
10. Open all cabinet doors and storage compartments to allow good ventilation. And stand cushions on their edge.
Jul 26, 2016
94
American Sail 18 MDR
You need to add fuel stabilizers to fuel (stabil?) and, if diesel. you need a biocide to keep plants from growing in there. If it rains a lot you might cover top of vessel with appropiate tarp. leave vents and an access doorway.
Aug 3, 2005
56
Currently boatless - Eastern Seaboard
The trawler I bought sat on the hard for 22 years. The batteries were fine once charged, and the two diesels started right up and ran beautifully on 22 year old diesel fuel. You might consider removing the negative battery cable just so nothing can drain the battery.
7,745
Alden 50 Sarasota, Florida
I'm not a particularly religious person so I'm unqualified to judge but in your case, I'd say prayer must work wonders.
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
Hopefully it won't take long to sell. My Macgregor sold in January!. It was a miracle. She was on the trailer in the boatyard with the sails off, ready to ride out winter. The lake's ramp areas were frozen. The just before the potential buyers came down hoping for an unlikely test sail, the cove thawed. We put on the sails, launched and went out for about an hour. Then we had to close the deal and pack her up for a 300 mile trip to her new home before it got dark.
Dec 2, 1997
9,011
- - LIttle Rock
In addition to the above suggestions:
Pump out and THOROUGHLY rinse out the holding tank before winterizing the toilet. To winterize the toilet correctly, remove the flush water inlet hose from the thru-hull (might be a good idea to close the seacock first if the boat is still in the water), stick that end of it into a jug of antifreeze...flush it through to the tank.
