LONG SHAFT
Don: It has been a while since I had my 25, but I definitely agree with the previous post that a long shaft is your best bet, even if it costs a few extra $$. When your "significant other" decides to do some sunbathing on the bow while you are motoring, the last thing you want to do is force her back to the cockpit and ruin the scenery in order to keep the prop in the water! As for size, you are right that the smaller HP outboard would probably move the boat under normal (calm, low wind) conditions, but if you venture outside Point Loma and ever do any "distance" sailing, you may really need the extra punch the 9.9 provides when the seas kick up. Isn't it great to get advice from fellow sailors that cost you extra money!!! Good Luck and smooth sailingTim Leighton (S/V "MAGIC")
