Mark Johnson
Hey Peggie...just to let you know that, as suspected, the hoses were permiated. Replaced all the hoses the odor is gone. There is one last hose that I have put off replacing because it runs from the bottom of the holding tank to the maserator. It is only about 30" long, but I don't see anyway to replace it without spilling any residual waste into the bilge while taking the old hose off. Because this hose is always full of sewage(being the low point of the tank),it has been suggested that I replace it with solid PVC (I forget the number) with a small piece of the white Sealand hose at each end to make it fexible. Does this make sense to you? My inclination is to "let sleeping dogs lay" and not replace it until I smell it. I am certainly open to any suggestions you may have. As always, I appreciate your input. Thanks, Mark Johnson
