I prefer to reef
Naturally this is subject of divergent opinion. I generally am, like you, reefedwhile others are sailing at incredible angles of heel (which, I admit, can be fun, and give the sensation of speed). Besides from not racing, and not being in a hurry to get anywhere, My reasons are as follows:First and foremost, I don't like to abuse my gear with unwarranted stress loads. Second, I don't like to place myself in a situation in which I must continually adjust sails. Third, my c-22 handles best at slight, rather than extreme angles of heel. Fourth, I don't like it when my drink spills. Next, consider the "slot" concept which is the prima faci of sloop, cutter, and marconi rigs. The jib and main have an optimal combined setting which we all constantly strive for. To have to spill wind regularly would defeat the purpose of this arangement. Now briefly analyze how sloops harness wind power and tansfer it into foreward momentum. The wind is collected by the sails, which have a center of effort. when this center is too high fo the amount of power, wind power is not effectively transferred to foreward momentum. This causes exessive heel which is momentum in the wrong driection. Sailors counter such heel by applying greater rudder angle, which acts like a break, steering into the wind, which de-powers sails, or spill the wind fom the sails, which not only de-powers them, but brings the up the sail re-setting can of worms. Reefing lowers the center of effot. A boat can be steered without excessive rudder angle (friction). As a result, it is more stable and able to handle puffs and other varialbes with a minimum of effort. The rig is under less stress, and can turn wind power into foreward momentum more efficiently. Your course won't suffer so much from leeway. There are also reasons for crowding on sail. Racing, naturally is one.I will end by saying that on my 18 year old sails are in prime shape for their age and have degraded little if at all over the course of my 5 year ownership of year-round usage.Rico.
