shifty thin
Water depth is not a certain thing, even in well charted areas if you sailing the Gulf coast or Atlantic coast of the southern US, where big storms, and hurricanes cause major changes in bottom contours, in a matter of hours. Just look at Google Earth, the satellite before and after pictures of this seasons storms and you can see actual botoom and beach changes that will not appear on charts for decades due to cut backs in funding for coastal surveying.I've seen old sailing passages in Florida fill up overnight and become land. Islands cut in two, islands become peninsulas in one storm. And then you factor in all the trees, containers, boats, etc. sunk during hurricanes, and all the navigation in the world just doesn't work like you want it to. Check local knowledge, consult the tide tables, post a lookout, proceed with caution and cross your fingers is the best one can do. I'd never lock my keel down, even in the open ocean, unless in major storm conditions. It's not built to take a direct hit at speed.
