E
Eric
I have a 380 which taking down the rivers from Minnesota to the sea this fall, as we start the great circle.I am thinking through seaworthiness issues and the one I want to ask you all about has to do with the lids to our lockers in the cockpit and the two on the tail. I am concerned about what happens WHEN I will get caught at sea in bad weather and I get pooped and the possibility of serious water coming in through these lockers.The two on the tail have the rubberized, springloaded type of latches to which I am going to add lockable brass latches. These two lockers open to large lockers in the tail which are separated from the INTERIOR of the boat by only a light wooden partition wall. I assume they drain nowhere else but into the bilge. If there was enough water, I am concerned that it would go to the bilge via the stateroom.In our round cockpit, there are also three lockers: one appears to be contained but has no drain, the two at the aft end of the cockpit are not contained and would empty quickly into the two large lockers off the aft end of the boat. If you open the port side aft locker in the cockpit and the port side aft locker on the tail, two people could reach in each one and shake hands in the middle, over the fuel tank, the head tank and a "bunsh of stuff".So if a wave comes over the rear of the boat, there is nothing to keep the locker lids from opening up and becoming gigantic funnels emptying into the interior of the boat.I plan on adding locking latches and good seals. Anyone have comments, ideas?
