C
Charles Duhon
I was glad to read the discussion about locking the prop in reverse when sailing.Should I put the transmission in reverse gear while the engine is running and then shut off the engine?I don't ever switch gears unless the engine is running at idle, and what about starting the engine while it is in reverse gear? wouldn't it be harder to start?Charles Duhon"Artistry"
