I have a Selden in mast RC Mk-III furling system on my Hunter 41. About a year ago I was having a lot of problems with the sail binding up when I was unfurling. This would happen no matter how carefully I held tension on the outhaul when furling in to avoid a baggy furl.
Well one day a rigger suggesting checking the foil tension. He explained that I needed to remove the sail to do it properly, slide the locking tube up to expose the tensioning screw and then adjust the foil tension so that it just barely slapped the inside of the mast when you grab and shake it. So, I did as he instructed. Once the sail was removed I didn't see the locking collar but I did find the tensioning screw so I adjust it as instructed.
Then the light bulb went on. Where is the locking tube?? It didn't take long to find - it was stuck up inside the halyard swivel. How did it get there? The last time (or who knows when) the mainsail was lowered halyard swivel was brought down on top of the locking collar and when the main was hauled back up it took the locking tube with it. So the furling drive had been disengaged from the foil for quite a while and this resulted in a bagged up furl.
I suspect that there are many others that may be experiencing similar furling problems that may likely be caused by the same problem that I discovered on my boat - the furling drive is not engaged to the foil because the locking tube has been drawn up inside the halyard swivel.
OK, so it turns out that there is a tiny little screw hole in which a tiny screw of unknown thread type is supposed to keep the locking tube in place. This screw is referred to as the lock tube retaining screw in the Selden manuals. This is the ONE PART that is most likely to be lost when working on the furling system but do you think that Selden lists this screw in the parts manual - well no that would be too logical.
I have tried an M4 screw as well as #6-32 and #8-32 and nothing threads into the hole properly. I pretty sure that it is a metric thread and I don't have ready access to metric screws that are smaller than M4 and it seems to me that an M3 would be too small. Does anyone out there know what type of screw goes in there?
