Location External Gas Tank
22
Hunter 25.5 Chelsea NY
I have a Hunter 25.5 with Honda 9.9 outboard. As far as I can tell the external gas tank is supposed to sit in the back of the cockpit next to the motor.
There does not seem to be a place for fuel lines to run into any of the compartments. It is no big deal, but takes up some space, and I like to smoke a cigar now and again.
Any suggestions?
-na -NA Anywhere USA
Anytime with gas nearby, I suggest do not smoke as anything can happen. Before selling boats, I use to be an investigator and investigated many fires over the years and you would be surprised how fires started due to far away fuel fumes.
Apr 16, 2010
79
88 Hunter 30 Solomons, MD
I had the same boat, and kept my six gallon tank there without any issue for two years. It was always full, since I rarely used the engine, and had no leaks of any kind. I've had a couple of people onboard with cigars, but I made them go forward to light them.
I say if you are sure that the tank has no leaks that you'll be fine. Throw in a light breeze and I'd worry even less. That said, having a good fire extinguisher on hand is a pretty good idea if you decide to continue your habit.
Dec 24, 2011
81
Hunter 33C Chesapeake
I also have a 1984 25.5
My 5 gallon tank is under a cover which is hinged at the top.
here's the best picture I could find.
Apr 16, 2012
22
Thank you for all the help. The picture is great. Is that commercially purchased?
