I notice that there is a conduit for the wires built into the deck, and it travels right by the head area.
This is the area that I will need to create the deck plate opening.
Does anyone know how wide this channel is?
If I just locate the deck plate as close as I can to the head window port, will that be ok?
Also, I am now thinking of putting the vent on the side of the hull, and making it a 1 inch white plastic through hull. I will glue some screen over it to prevent bees getting in.
How does that sound?
I will put the connection to the top of the holding tank as close to the inboard edge of the tank as possible, so that if I am heeled to a large angle, seawater will have to travel farther up the vent pipe to get into the holding tank (likewise with the sewage getting out of the same port).
Roy_______________________________________________
Join Excite! - http://www.excite.com
The most personalized portal on the Web!
