Has anyone with wiring similar to a 2005 Hunter 41 converted to lithium house batteries? I'm having a hard time deciding how to separate the House (lithium) and start (AGM) and power the inverter and windless from the house batteries . If I connect the windless and inverter to the house side thru the House Battery Switch, when the battery switch is in "Off" position , current is still directed to the inverter and windless while the engine is running through the "combiner". I believe the problem here is that the current will also flow into the house lithium batteries from the engine and charge them outside the lithium charging parameters.
I have tried connecting the windless to the "Start Battery" switch from the house side of the combiner. This leaves the house batteries separate with now current when the engine is running. However, the windless is only drawing current from the "Start Battery". I definitely don't want to kill my start battery. I would prefer to keep the windless on the house side, but don't want to charge the lithium batteries from the engine. I have a DC-DC charger for that.
I am charging my lithium batteries mainly with 400watts solar and a 40 Amp DC-DC charger. Also have an AC charger if needed.
Any suggestions appreciated.
Battery panel wiring attached.
