Lines
12
Hunter 40.5 Port Charlotte
I have to replace several lines that run under the deck cover plate leading back to the cockpit cams/clutches. Is there a clever way to route these new lines without removing this deck cover piece (the old lines have already been removed)?
Jun 6, 2006
6,990
Nope, and depending on which version of the sea hood (cover plate) you have you may have to start cutting to gain access to the three sets of deck organizers.
Does your boat have the sea hood divided into two sections? Some have a seam forward of the solar panel that can be removed by just taking out the four hold down screws and some have a one piece design that would require you to take off the traveler.
Scott
Sep 24, 1997
242
Hunter 31_83-87 Middle River, Md
Can't you join the ends of the new and old and simply pull them through?
gpdno
May 16, 2011
144
Watkins 27 Venice
You might try a wire fish. I use mine to run electrical wire. You can buy them at most hardware stores.
dqb24
Nov 4, 2011
49
Quintessence Hunter 34 Annapolis, MD
Now sure how big your 'tunnel' is, but on the H34, an average sized boathook - entering from the cockpit side - works great...insert boathook all the way through the tunnel, tie new line on by the mast, pull aft. Ta-da.
-na -NA Anywhere USA
When running old lines with new lines in that area, dealers and yards would attach what would be called tracer lines. at the end of the lines, add a small line attached to the ends. You can use a medium phillips or the one smaller than standard to put a tracer line in and use a bowline on each end and pull keeping tension at all times so the tracer line will remain on the hard to get rollers.
