This my first boat and it has been a good boat this far. However, I am 53 years old with a spouse who is a reluctant and anxious sailor. She hates it when I go forward to raise the main leaving her in the cockpit alone. For reasons of domestic tranquility, and safety, I would like to be able to raise the main from the cockpit. My boat has boom sheeting, with a traveler that is at the end of the cockpit. I also would like a 150 Genoa with roller furling. I would love your advice on how to set up the boat in a way that will be efficient and cost effective. I would consider doing some DIY if feasible. I see 4 options in ascending order of expense and difficulty.1. I just run the halyard back to get the line to the starboard winch (there are no winch’s on the cabin top). The obvious problem is that this would leave the reef lines at the mast. I assume that would not last forever, although all of my sailing is on the Columbia River 2. I could run the halyard for the headsail, mainsail and reef lines back. This would probably require me to get two or three winches. This might be the best solution, but probably the most expensive.3. I have three lines at the mast, one reefing, one outhaul, and the third I do not know what it is for. That would allow me to bring the reef line back to the cockpit. However, would I need to install a winch for these? I have no boom vang although it looks like it had one installed at one time. There is a wire on the back of the boom I think it is a topping lift. I also have a Cunningham. I would appreciate any advice that any of you can give me. I would be delighted to entertain any additional options.
