I have a 1987 O'day 322. I am trying to find out line size and length for the Main Halyard, Jib Halyard, Main Sheet, Jib Sheets, Topping Lift and Reefing Lines. Any help would be appreciated.
Check the top of this page under "Resources", then click on "running rigging specifier". You can at least get an idea of line size. Length is a different issue, they don't tell you how long the line is that you are buying (or "fake" buying). The best thing to do is use existing lines for length measurement and adjust to suit your needs.
