Line Drawings for H22 Early 80's
203
Nov 5, 2013
73
Hunter 22 1983 Lake Norman
I've found reference in the archives for such a drawing. However unless I'm blind ( good possibility ) I can't find these drawings now. At least not in the downloads.
I need a scale drawing of the H22 so I can do some fitup work with a trailer I got for mine. Any help would be appreciated.
Thanks
Richard
SeaTR
Jan 24, 2009
408
Hunter 22 Groton
re: "any help"...
Richard,
I don't have any 'drawings' of my '81 H22 / trailer, but I have converted my recently created Power Point file of the boat and trailer into a .pdf format with many dimensions annotated.
This is the closest that I can come to what I believe you are looking for.
Let me know if there is anything else that you may need.
Happy New Year !
Charlie
Nov 5, 2013
73
Re: "any help"...
Charlie and Brad,
Thanks a bunch. Charlie, your numbers will help a bunch with my remodel of this trailer. Big help (c:
Brad, that drawing is similiar to one I have a paper copy of, and it's so tattered and written on that it's almost gone. The one I have is a scale drawing, at 1/8 scale. I printed the one you send and it's not 1/8 but printed out without modification, it at least is an interger multiple of 3/16 scale which is better than I have right now. Thanks !!
Everybody have a safe New Year. I'm going out tomorrow to pull my mast over on the dock, climb up my big step ladder and clean up the spreader / shroud interface. Might go by West Marine and see if they have any of those special boots. If not then carefully applied rigging tape should do it (c:
Richard
203
Nov 5, 2013
73
I had found in earlier searches, this link...
http://forums.hunter.sailboatowners.com/showthread.php?t=45541
However I have not had any luck finding any drawings to go with it.
I was especially interested in the last comment where someone had put the plans and profiles into AutoCAD. I use AutoCAD here, and could easily convert anything I have in ACAD to pdf in case it was of any value to other DIY sailors. I'm still working on that, and Charlie's notes will help a bunch.
The guy 'Jim' in this link is registered as a guest, and there is no link to him for communications.
Anyway I appreciate every one's efforts.
Richard
