Shaft Razor
I put a cutter, the Shaft Razor brand, on my shaft after I installed a feathering 3-blade prop. I was concerned with possible damage to my prop with wrapped lines.
I have had the cutter sever numerous lines. Almost all the lines cut were because the pots were underwater and could not be seen.
However, one line that was floating in the water and not attached to a trap was wound up on my prop without any cutting action. In order for the cutter to work, I guess it must need one end of the line fixed so that it will pull tight across the cutting surface.
I am always mindful of the cutter whenever I dive on the prop and I give very strong warnings to anyone else that is doing the same. You must be very careful in the Spring when working around the cutter also. It is EXTREMELY sharp.
Link to manufacturer:
http://www.evolutionmarine.com/detail.html?id=3002&cart=12316008619788930
I have no connection to them, only a 8-year customer.
