I'd like to know what you'd do in light to very light winds considering the controls I have. I only want to talk about the main as my jib is on a furler and I have fixed fairleads.
I have a fractional B&R rig which means I have no back stay.
I've got the main halyard, outhaul, boom vang, and main sheet.
I do not have a backstay, traveler, or cunningham.
I've got Don's book but it talks about many sail shaping tools I don't have.
What I've been doing is as much tension on the halyard as I can, otherwise the draft always seems to be too far aft (I may need to loosen the bolt rope). I leave the boom vang loose so the top can twist open to get tell tales flying properly along the entire sail. The outhaul is tight to reduce the draft.
I've been watching other sailors out on the lake and they all seem to try and reduce twist. If I do that the same then my upper tell tales say to let the sail out while the middle and lower fly correctly. I thought in light to very light winds, the water causes friction that causes a difference between what the wind is doing higher up the sail than what it's doing low. In order to use the entire sail, you have to twist the sail in order to get power from the entire sail. Otherwise, you're only using the bottom 2/3rds or so. And then flatten the sail to keep the air flow attached.
Considering what other sailors are doing, I'm wondering if I'm wrong? I've also got a main with a large roach so I'm not sure if their sails can be twisted but not look as twisted as mine?
