Limber Hole??
Feb 21, 2008
418
Hunter 33 Metedeconk River
In my 2006 H33, as you enter the rear cabin and lift the first cover under the mattress support, is a space that only has the white 1.5" head drain going thru it toward the holding tank. At the bottom corner of the port, forward area there is what appears to be a drain hole molded by the fiberglass. Does someone know where this goes and how it can be cleaned? I have searched my owners manual and find no reference to it in any section.
Thanks.
Jun 2, 2011
347
Hunter H33 Port Credit Harbour, ON.
I am not absolutely positive but I think that it allows water to drain to the bilge. The water will most likely show up in the area where the shut off valves are before flowing to the next bilge. I have not had to clean out from that area but I have cleaned where the head hoses go down through the floor behind the manual pump. The water ends up in the above mentioned bilge. It takes a couple of sails to get all the water dried out.
Nice boat by the way. ;-)
