Each link in the old man's chain connection is a small electrical connection that will rapidly increase in impedance as more current is applied, such as in a direct strike. Same is true for shrouds and stays, turnbuckles and hooks will conduct electricity, but will not efficiently pass the surge. An example is to take a look at the guy wires supporting a radio tower. They tension those cables with turnbuckles, but usually attach a wire across the turnbuckle to more efficiently conduct the surge. If you look inside the radio hut, they typically do the same across metal electrical conduit junctions, outlet boxes, and switch boxes. This is because the regular attachment is not suitable for high current, or lower current in many cases even.
High current surge energy does not want to make turns as it travels toward earth. Sharp bends in wires are common places that get blown out and surge arcs to something else - possibly a person nearby. This is the reason for grounding. The jumper cables and chain are not ideal and the chances of it working effectively are not too good. Ideal would be a direct straight path to ground with no 90 degree turns on the main absorber. Any necessary turns should be gradual, but a metal keel in the water with a #2 wire bonded to the mast is much more likely to be efficient and safer.
Electronics can be reasonably protected from induced current caused by nearby strikes or delivered via shore services. Surge suppressors are designed for this type of protection, not direct hits. Real surge suppressors, not power strips with a single MOV across the leads, are effective. Companies like Raycap make very good "whole house" suppressors that could be incorporated to the AC supply provided there's a good path to ground. Coaxial RF suppressors, ethernet, telephone, & cable TV are other entry points that should be protected with a suppression device. All require good ground connections to work.
