Ben Franklin
I spoke last month with a gentlemn who retired after owning the largest lightning rod installer business in the US. Many famous landmarks protected by his expertise. He said: the best protection possible is by a "Ben Franklin", which is a solid copper or brass rod, of at least zero gauge, pointed on the top end, connected to a stranded cable of at least 4 gauge copper, leading directly to ground or water. National Fire Protection Association has rules and standards for lightning protection for vessels. You can read them online. I've forgeotten the chapter and paragraph numbers, but it worth reading. All metal in the boat and all electrical systems should be grounded to the same commom ground, but the lightning should have it's own, shortest path to ground, separate form the boat's electrical system.
