LIGHTNING PROTECTION SYSTEM
DAREK PIATEK
Hi i purchase 2 years agoe 1978 oday 30'.The boat has missing wireing for lightning protection. If any body can provaide the spec. and leyaout of wires. Thanks Darek
bruce cornell
lightning
since nobody has said anything, you need a heavy solid copper, see house grounding kits, a direct route with no sharp bends from the mast or tabernacle to the keel bolt or ground plate with oversized connectors at each end, if they burn off they don't work. you can also attach a length of anchor chain to a stay with a cable clamp(kind with nuts) and drag over the side in an emergency. chain should be 3 feet or more into the water.
