lighting wiring
1
- - san diego
I have c30 1978 with only one light that works (over the stove) the rest have had exposed wiring run to them by previous owner. is there a way to get as the wire runs to check for problems? the original wires are still sticking out under each light.
You're lucky
most skippers complain that the older Catalina light wiring is embedded in the fiberglass!!! Be HAPPY that you have what you have and simply replace the wiring since you can get to it. Also check the C30 Association website www.catalina30.com
