On a few occasions -- not always -- I've felt a slight electrical tingle when running my hand along the boom as I work my way across the cabin top. It happens when the sail cover is still on; typically when I first get onto the boat at the dock. I don't ever recall feeling it when touching the boom directly, when away from the dock, or when putting the cover back on and leaving the boat. Is this something I should be concerned about? Here are a few more details about my setup:
The boat has 2 batteries, 1 house and 1 starter; they're wired via a add-a-battery switch. I feel the tingle when getting on the boat and the switch is set to off. The system is NOT grounded to the keel.
There is no shorepower to my boat (nor is it wired for it). Most of my neighbor's boats are hooked up for power.
The boat has an outboard; it's always fully out of the water when not in use. The boat has a lead keel but other than that I don't know of a metal to water contact. There are thru-hull transducers for speed and depth, plus a newer shoot-thru transducer in the stern.
There's a small 5W rated solar panel on the stern rail to trickle charge the batteries.
My 12V system is mostly new, robust, and as far as I know working properly.
Could the mast/rigging just be picking up a little stray charge from the air?
Anyone ever heard of anything like this, and is there a solution or it even worth worrying about? Maybe it's just some static I'm brining on board when I first get to the boat?
