So I got below in 21' Mcgregor and I am seeing light coming through the front lower V shape part of the boat right about the area where the boat can be rammed on the beach. I looked on the out side and the paint/gelcoat is scratched and I can see the fiberglas and that is exactly where the light is coming through.
How thick do you think the fibergalss is there and do I need to be concerned?
Once the boat is stable on the trailer I will fill with water to see if I have any leaks in tha area and also around the bolt that holds the keel in place where I see lots of thick rust.
The boat had about 3" of water inside when I purchased and the last owner told me that the water is from the washing the boat and also from the rain (no much rain in So Cal) I do believe him but I am about 2 months out of finding out.
Thanks Costy
Ps. As I am writing this I am thinking that I should have saved some of the water before I drained and ran it in the Ph metter @ work and see if it was salt water
Thanks Costy
